# Page Not Found
The URL `netzbetreiberinfo/netzbetreiber/p.k.-energieversorgungs` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [P.K. Energieversorgungs-GmbH](https://docs.eg-austria.at/netzbetreiberinfo/netzbetreiber/p-k-energieversorgungs-gmbh.md)
- [Energie Güssing](https://docs.eg-austria.at/netzbetreiberinfo/netzbetreiber/energie-gussing.md)
- [Energie Ried](https://docs.eg-austria.at/netzbetreiberinfo/netzbetreiber/energie-ried.md)
- [Energie Klagenfurt](https://docs.eg-austria.at/netzbetreiberinfo/netzbetreiber/energie-klagenfurt.md)
- [Netz Oberösterreich](https://docs.eg-austria.at/netzbetreiberinfo/netzbetreiber/netz-oberoesterreich.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
Perform an HTTP GET request on the documentation index with the `ask` parameter:
GET https://docs.eg-austria.at/netzbetreiberinfo/netzbetreiber/p-k-energieversorgungs-gmbh.md?ask=<question>
The question should be specific, self-contained, and written in natural language.
The response will contain a direct answer to the question and relevant excerpts and sources from the documentation.
### Option 2 — Browse the documentation index
Full index: https://docs.eg-austria.at/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.eg-austria.at/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/netzbetreiberinfo/netzbetreiber/p-k-energieversorgungs-gmbh.md`).
You may also use `Accept: text/markdown` header for content negotiation.
